New create shape tool
Just select which mode you want (both, outline only, or fill only) and this create shape tool will create shapes accordingly. No more creating shapes and then unchecking either the fill or outline option in the styles window for each shape you create.
Download the zip file here.
Just unzip and drop the three syn_create_shape files into your AS/scripts/tool folder. If you don't already have Fazek's utilities, drop the fa_sharedutils file into your AS/scripts/utilities folder.
This is a mod of Fazek's tool, so you will need the fa_sharedutils required for those. Also credit to Rasheed for his no line create shape tool.
Note: You cannot create a 'fill only' shape unless the shape is closed.
Please let me know if you find this useful. :wink:
absolutely useful!
thanks! This week I were to write a script request asking exactly what you did (but then forgot it :oops:), now things will be so much faster. thanks.
This is GREAT. For some reason I wasn't understanding what this was. It didn't click. Now I GET IT!
You should post a link to this thread in the general topic area. I think some AS users are "afraid" to read these threads or think that scripts are only for advanced users which might be why they don't see these posts.
toonertime
bent out of shape
Post by toonertime »
i am trying to use this script. say i make a circle
with a color and no outline. i use the tool, pick a selection,
and really nothing changes!
what is this idiot not doing right?
Tooner, this is a 'create shape tool', just like Fazek's or LM's. It doesn't do anything to already created shapes.
Try this:
1) create a circle without any fill or outline, with the oval tool
2) using syn_create_shape tool, select what kind of shapes you want to create (both, outline only, fill only) in the tool options at the top of the workspace
3) with this tool, define a shape to be filled
4) hit the space bar to finalize the shape
The 'both' option will create both fill and outline, and the other two options will do each separately.
Selgin
Glad I could fill the need in advance of the request
Vern
I hadn't thought of that. Here I was feeling underappreciated. :roll: You're probably right. I'll post a link elsewhere.
toonertime
bent back into shape
thanks for the 2torial
now i see, said the blind man!
blacksunproject
Re: New create shape tool
Post by blacksunproject »
synthsin75 wrote:Image
Just unzip and drop the three syn_create_shape files into your AS/scripts/tool folder. If you don't already have Fazek's utilities, drop the fa_utilities file into your AS/scripts/utilities folder.
This is a mod of Fazek's tool, so you will need the fa_utility required for those. Also credit to Rasheed for his no line create shape tool.
Where can I get the fa_utility needed for this tool?
Thanks in advance,
Gustavo
Oops, sorry about that. The Fazek utility is actually called 'fa_sharedutils'. I'll fix the first post. :wink:
Here's a version without flood selection.http://www.mediafire.com/?ymvxt2ebjhg
blacksunproject
synthsin75 wrote:Here's a version without flood selection.http://www.mediafire.com/?ymvxt2ebjhg
How do you use the orbit tool?
blacksunproject
Nix my question!
The Orbit tool is incredible!!!
Uh......orbit tool?.....what orbit tool?........I don't think I've ever posted anything about the orbit tool. I'm very, very confused. :?
blacksunproject
synthsin75 wrote:Uh......orbit tool?.....what orbit tool?........I don't think I've ever posted anything about the orbit tool. I'm very, very confused. :?
and I love the way it works.
Gustavo
uhm, can you post the orbit tool file?
are you sure it's not the classical orbit tool of AS?
