timeline: "enable graph mode" hides bone angle key
p8guitar
Post by p8guitar »
When I switch the timeline to "graph mode", I don't see the "bone angle" and "selected bone angle" keyframes any more.
(Schenker W507, i7-6700 CPU @ 3.4 GHz, 32 GB RAM, NVIDIA GeForce GTX 1060, Windows 10, Moho Pro 13.)
Graph mode can be a bit confusing. I thought the same thing when I first tried it. You have to make sure you select the channel on the left and also scale the graph view so you can see the keys.
Fiddle with it. It should work.
p8guitar
Post by p8guitar »
hm, ok... now I see them, not sure how I did that...
But I find it very puzzling that the point motion channel vanishes when graph mode is turned on. It is the top channel, the channel below that is "selected point motion", which doesn't vanish.
there are two keyframes in the point motion channel (I moved some points of some shapes to change the expression of a face).
