How do I delete a keyframe?
p8guitar
Post by p8guitar »
very basic question: I want to get rid of an animation that I don't need anymore. How do I delete a (point motion) keyframe in the timeline? the obvious methods don't work (del, backspace, right-click-menue...)
Peter
(Schenker W507, i7-6700 CPU @ 3.4 GHz, 32 GB RAM, NVIDIA GeForce GTX 1060, Windows 10, Moho Pro 13.)
Select the key (the dot in the time line). It turns red. Now press the "delete" button on the time line. You can't use the delete key to remove key frames. You must select the key and use the delete button.
alt+backspace works :)
p8guitar
Post by p8guitar »
heyvern wrote:Select the key (the dot in the time line). It turns red. Now press the "delete" button on the time line. You can't use the delete key to remove key frames. You must select the key and use the delete button.
oops. there is a delete button... :oops:
I actually missed the most obvious... thanks, Vern!
And thanks for sharing the "alt-backspace" trick, funksmaname!
funksmaname wrote:alt+backspace works :)
Good grief! Did I already know that one and forgot? I don't think so... good grief. GREAT TIP!! FANTASTIC TIP!
madrobot
Post by madrobot »
Wow, that is a great tip!
I wonder - are there shortcuts for copy paste frames?
alt+V, alt+C for copy/paste keyframes. :wink:
w00t! I found something The Oracle didn't know... I will now be smug all day. :wink:
funksmaname wrote:w00t! I found something The Oracle didn't know... I will now be smug all day. :wink:
:D yes, it feels good.
