Probably a silly question.
How do I render a still image with an alpha?
So when I open it in Photoshop it has an alpha?
At the moment I select and delete the background colour
but would be nice to bring it in with transparency.
Render a still with alpha
NetGenSuperstar
If you're exporting to a format that supports transparency, such as PNG, it should be transparent in any part of the image with no filled shapes. For example, if you select File->New, and export that blank canvas to a PNG, it will render a fully transparent image.
So I guess the question would be, what image format are you saving to?
The enrichment centre is required to remind you that you will be baked, and then there will be cake.
