Layers drifting apart in an animation
the_other_lt
Hi, this is my first time posting on this board. I looked around before, but couldn't seem to find an answer to this problem.
I'm very much a beginner with AS (done the tutorials; don't have AS Pro) and I made an animation to test bone animation and the like. It involves a fly zipping around a bit before lighting on a table and getting swatted. The problem I'm having is while the fly is moving around before landing, his wings (set one layer above his body) tend to drift behind the body. Everything is part of the same bone layer and I tried tweaking bone constraints, but that didn't seem to affect anything.
Any suggestions for a noob?
the_other_lt
the_other_lt
I changed it to region binding (even making sure to set region binding on the switch layer that included the fly's bone layer) and I'm still having the same problem. I'm trying to figure out what else it might be.
The animation itself isn't important to me; I'm just making this particular one to try and get the hang of bones and it's a little discouraging to run into a problem like this right off the bat.
???! Switch layer? Okay, I don't seem to have the whole story here. Your best bet is always to share an example file by hosting it at Mediafire or elsewhere, and then posting the link to it here. But I'll make a few more guesses at your problem.I changed it to region binding (even making sure to set region binding on the switch layer that included the fly's bone layer) and I'm still having the same problem.
First, check each layer for any stray layer translation keyframes (make sure this channel is visible in the timeline settings). You're not using Pro, so we can rule out 3D camera causes.
I don't quite understand how you're using the switch layer here. If you could post your layer structure, at least, it may help.
For example:
-Fly switch layer
--Fly bone layer
---body vector layer
---wing vector layer
--Fly bone layer 2
Etc, etc..
As a general rule, sharing an example file will get you a faster solution as it avoids all of the guesswork, especially when people may not yet be completely familiar with the terms and software. Usually these things are solved very simply, but we have to figure out what could have gone wrong.
Since you said this animation isn't important, I'd suggest uploading it to http://www.mediafire.com/index.php. After uploading you will get a url to copy and paste here.
the_other_lt
That's fine. Did you want me to just upload the exported animation, or the AS file itself?
Here's the layer order:
Arm and Paper (bone)
---thumb (vector)
---newspaper (image)
---hand (vector)
Fly (switch)
---Fly (bone)
------Wings (vector)
------Fly body (vector)
---Bug guts (vector)
Table (vector)
The switch layer is the fly after it's splatted by the newspaper.
---thumb (vector)
---hand (vector)
Fly (switch)
---Fly (bone)
Table (vector)
the_other_lt
Just a heads up: I'll get the file uploaded as soon as I can. You can thank the remnants of Hurricane Ike for knocking out my power (that, and my cable modem gave up the ghost a few minutes beforehand anyway). I'm posting this reply from school, so as soon as I can get my laptop near a wireless signal, I'll put the file on MediaFire.
the_other_lt
I'm actually in Louisville, so we're sort of the border between the South and the Midwest ... hardly a hurricane zone. It's just that Ike was freakishly strong over land and it happened to take just the right path inland, but it's passed now.
Anyway, here's the link to the file:
http://www.mediafire.com/?sharekey=5d0d ... b9a8902bda
And yes, I realize that the bug's guts are not in the same spot as his body before the newspaper came down. I'm doing this to get the gist of bones and such.
The motion blur on the wings is what is causing this. The blur is not only blurring along the 'flapping' of the wings, but also along the layer translation movement.
The way to solve this is to do your layer translation of the fly on its switch layer. This way the wings layer is technically not moving in relation to its top parent layer.
That's how it usually goes. The problem is commonly something people just don't think to mention. Hopefully this helps cure your frustration.
the_other_lt
the_other_lt
