Standard Version Effects
technoweasel
Post by technoweasel »
If you only have the standard version of Anime Studio you might want to try using other software for effects. I tried out a free 3d program called blender and, although it is a bit difficult to learn, you can use it for particle effects, etc. When you render, just save it as quicktime png with Millions of Colors + so it will have transparency. It can then be imported into AS5 as an image layer.
Freakish Kid
Re: Standard Version Effects
Post by Freakish Kid »
technoweasel wrote:If you only have the standard version of Anime Studio you might want to try using other software for effects. I tried out a free 3d program called blender and, although it is a bit difficult to learn, you can use it for particle effects, etc. When you render, just save it as quicktime png with Millions of Colors + so it will have transparency. It can then be imported into AS5 as an image layer.
Actually a great program to use for particle fx is a program called Particle Illusion, we use it for all our vfx.
GK
J. Baker
Post by J. Baker »
Also, check out EffectsLab. ;)
http://fxhome.com/effectslab/pro
