.SWF FILE HELP!!!!!
- H.G. DaGr8One
.SWF FILE HELP!!!!!
I made a cartoon in .swf file format. But when i watch it on my .swf player it looks distorted, ex: scenes blending in with each other, lines coming off of my characters, different colored blocks in the background. The sound even sounds bad it's like choppy. I've watched it on several different players and it's the same thing...DISTORTION!!!!
But when i look at a preview/render of the individual scenes on ASP they look good. When i play the cartoon on ASP everything looks good even the audio is good. My files are optimized everything seems good. WHAT AM I DOING WRONG??
I'm trying to submit my cartoon to a flash based site (Newgrounds.com) but i can't fix the...glitches...on it. I SERIOUSLY NEED HELP, PLZ.
LET YO' VOICE BE HEARD, BREAK AWAY FROM DA' FLOCK!!!
EMBRACE DA' ILLUSION OF LIFE!!!
In the meantime, you could try this:
1. Get Riva FLV encoder (Google for it -- it's free)
2. Export your movie as an AVI file
3. Convert it to FLV format with Riva
4. Open Flash, and Import the FLV file
5. Export your SWF file
The bad news is, this will be a LOT bigger than an optimised SWF file. But then, AS Pro never produces optimised SWF files anyway. At least your work won't be wasted, assuming the end result isn't too large...
Hope this helps,
J
Hope this helps,
J
Granted AS doesn't have full support for Flash but used correctly it can be effective in Flash production. It should be used along with Flash rather than as a replacement. In certain styles of animation, specifically "cut-out", AS works very well with Flash.
My main use for Flash export is for print. I can export to SWF from AS and use it for print media in Adobe Illustrator. I've done several posters using AS this way.
- H.G. DaGr8One
Yeah, I followed that to a "T". And made sure it was good to go. But still getting distortion. What do i do??Genete wrote:Read the built in help ->Reference ->Flash tips. There you can find:Probably it would explain your problems.
- What Can be Exported
- What Can't be Exported
- How to Create Efficient Flash Files
- What to Avoid
- H.G. DaGr8One
Yeah, Newgrounds only takes .SWF files. And they have to be 10MB. I may just submit it all messed up looking. But i won't be pleased.heyvern wrote:Before you try the FLV option you better check the requirements for submissions and make sure they accept FLV video. That site is a BIG Flash site, I could be wrong but FLV might not be what they want.
I would make sure first. I couldn't find any guidelines or submission requirements.
- H.G. DaGr8One
I guess i should of got Macromedia Flash. Dat' sux to hear. Do you know of any sites like Newgrounds that take the files that ASP puts out?... besides SWF. I'm trying to get this cartoon out here but keep running into little bumps.Samb wrote:if you don't use flash then you shouldn't submit your movies to newgrounds.. anime studio is one of the worst programs for flash animation. I don't even know why it got an swf export...
maybe for the advertisment?
I use AS to output swf files all the time...I also import them into Flash and they are fine....Like Genete says in his previous post...check the do's and don't for swf export. Things like using images, brushes and masking in AS will not export to swf. The best rule of thumb for sfw export is to keep to simple vector based animation.
Cheers
D.K
Cheers
D.K
I remember having a bit of a turn when I first played with exporting SWF's.
The main thing is to try get that little red dot on your layers indicating that it IS good for swf export, this isn't completely neccesssary but it will definitely get you closer to a good output.
As a rule if you should limit point animation, but really you don't have to go too overboard.
You will actually be surprised at how much anime will push past its own recommended limits to get out the swf, try turning off layers to find the major culprits, a little experience with this swf experimenting will go a long way to get your results.
You're not listening:heyvern wrote:Before you try the FLV option you better check the requirements for submissions and make sure they accept FLV video. That site is a BIG Flash site, I could be wrong but FLV might not be what they want.
jahnocli wrote:4. Open Flash, and Import the FLV file
It would still be flv video though just embedded as part of a swf- actually I think you would still need to upload the flv to a remote site for the swf to read from...
I think Newsgrounds is a site for animations that were actually created in Flash. SWF used to be great circa 1990 when you wanted to display cartoon animations on the web- but nowadays streaming video is such high quality that swf only makes sense if you want interactivity or to make a flash game. Flash is such a PITA to animate in I'm not sure why anyone would want to do it.
Exactly. FLV is NOT "Flash"... it is video. Newgrounds I think is very much a pro-flash site. Since FLV is just "ordinary" video it could be from any source it could be done with anything, even high end 3D software. Plus FLV files are much larger. The fast download is due to streaming, it still takes up much more space than an SWF. A Flash oriented site wouldn't be saving much bandwidth or space if they accepted FLV video.jhbmw007 wrote:It would still be flv video though just embedded as part of a swf
Because they spend a lot of effort and time learning how to do it. Kind of stuck. I started trying to do 2D character animation with Flash right before finding Moho. I had just started... yikes. If I hadn't found Moho I might still be hacking away with Flash.Flash is such a PITA to animate in I'm not sure why anyone would want to do it.
