Soundtrack issue when exporting to FLASH
saintmovius
Post by saintmovius »
I've read in the manual that if I use an .mp3 file for my soundtrack and export to flash that the soundtrack will also export...this however does not seem to be the case. My .mp3 file is 128kb and 44.100Hz, but when i play back the flash file...no sound! Any help on this would be great! Thanks!
Lost Marble
Post by Lost Marble »
Hmm, that should work. Can you post a link to the MP3 file? Or, email it to support@lostmarble.com.
saintmovius
Do you need just the .mp3 file or the whole animation? One more thing I might mention is that when i play the flash file it acts a little sluggish...odd?
Lost Marble
Maybe the whole animation. Is ti a very complex animation? The problem with Flash is that the more complex an animation is, the more work Flash has to do to play it back - that could be why it's sluggish.
A bitmap format on the other hand, like QuickTime or AVI, has to do basically the same amount work if it's playing back either the most basic Moho tutorial or The Lord of the Rings.
