Hi all. With my memory so bad I decided to try to set up a search feature for the Moho help files. I spend a bunch of time trying to setup a Google search and hosting a copy, then finding a script one to insert locally, tools to convert to PDF but finally settled on an ebook. I found a trial version of a ebook maker here
http://www.caislabs.com/index.htm
and after some trial and error I got it to work and posted the file here
http://stormvisions.com/moho/MohoManual5.zip
It's about 4.5MB. Now you can use the built in tools to search and do a few other things. Hope it is useful.
@LM - It has the trial message and says not to be used to sell commercial ebooks so I guess this is ok -as we aren't selling it but you may want to look. If I get some $$ later I'll pick up a copy and I can update this from time to time.
I tried to add the scripting reference but would have to redo the HTML and renumber the document tree code to put them all in the same TOC so left that out for now.
Finally I had been getting some javascript errors and I commented out these lines in the HTML pages and seems to work fine
// parent.tocFrame.d.openTo(loc, true);
In case anyone else has the problem.
Searchable Moho Help Files Posted
- Lost Marble
Re: Searchable Moho Help Files Posted
Win 7pro 64bit
This opens but will not show any content? it says "This page can’t be displayed" to all searches.
Regards
Chris.
Regards
Chris.
- Barry Baker
Same here. It seems to be looking for other material that isn't in the archive.videodv wrote:Win 7pro 64bit
Regards
Chris.
Considering that the ebook is nearly 9 years old, it's very likely that whatever pages it's pointing to no longer exist.
~Danimal
- Barry Baker
Danimal wrote:Considering that the ebook is nearly 9 years old, it's very likely that whatever pages it's pointing to no longer exist.
