Moho images
Darker
Moho images
Post by Darker »
Hi there, hope everybody's fine. I'd like to know if I can import an image (a picture of a head, for example) and draw a body to join both of them. How should it be done? One layer for the head and the other for the body then shall I use conect points to make both layers work as one??? The idea is a character half cartoon and half human, thanks... :)
Remember that bones work across all layers so you could easily have a vector layer (drawn in AS) along with an image layer of the head on top of it. the connection would be made with bones. Bind the head to the head bone of a skeleton and the body would be moved by the rest of the bones (neck bone, back bone, arms etc)
Connecting it is up to you. Most likely you would have a neck or maybe just shoulders so no real "connection" is necessary. The head layer would be over the neck or the torso and bound to the head bone and would stay in that general location when the bones move.
Darker
thanks heyvern
Post by Darker »
heyvern, now I understand, and thanks for your help :D
