layer point count script ?
dueyftw
Post by dueyftw »
I could use a way to count the points on a layer. This way I can use the morphing of the switch layer with two files that have been imported from AI by adding or removing the correct amount of points.
One way is to save the file and open in a text editor, then do a search. Got to be a better way.
Dale
I'm not sure this would help. I am far from an expert in this, but from what I have read on this forum, it seems that these points are numbered in unique ways, and it is only by using direct copies that interpolation can work properly in switch layers.
dueyftw
Post by dueyftw »
Your right. I did some tests and the points that interpolate are not next to each other. The effect is to have one layer folding to the next, some points moving to its neighbor and others moving from one side of the screen to the other in almost a random fashion. The only way that this would work is if one had a script that renamed each point of the layer from top to bottom or left to right.
Dale
viewtopic.php?t=8224
This thread has the best (only) solution to that problem I've seen. Reordering points and finding point IDs has been suggested, but no one has scripted a solution yet.
