Scene Selector
Scene Selector
Hi, everyone,
In order to make my life easier while using Anime Studio, I created the Scene Selector program (for windows).
The program is very easy to use: just double-click on the thumbnail and Anime Studio will open the file. There is a button to create the thumbnail for a given file, and another one to create all missing thumbnails within the folder. And, of course, it creates sequential backups of the file before opening it. These backups are created on a subfolder called "Backups" (duhhh!), which the program creates automatically, if it doesn't exist. The backups are created adding a "_" plus a sequential number, for example: Scene001_001, Scene001_002, Scene001_003, etc.
The program was created using Visual Basic, so I am including the setup program for it. You can download it here:
http://www.mediafire.com/?4ilo1qbtcvss9u3
Enjoy!
Enjoy!
- NightmanGX
synthsin75:
1. Did the error message appear when calling the Setup program, or after installing the application?
2. If the message appeared when calling the Setup program, be sure you unzipped the files into their respective directories (paths).
3. If the message appeared after installing, did you set the Anime Studio path with File-->Set Anime Studio Path menu option?
I tested it with both version 5.5 and 5.6 and it works fine.
- Víctor Paredes
- toonertime
quick question
I downloaded your useful idea.
I haven't run the setup yet, but I see that
there is one folder that has a setup
and another folder labled support that
has a setup as well. How do I install
yer program?
yer program?
toonertime:
synthsin75:
selgin:
Thanks everyone for the comments. Please let me know of any issues / suggestions.
Just execute Setup.exe. Don't worry about the other files and folders.How do I install yer program?
synthsin75:
I'm working on that. The trick is that the program does not create a thumbnail for every file on the directory, since it takes too much time (not only should the program display the thumbnail, but it also reads the file to get some information such as fps and scene duration). Instead, there are only nine thumbnails which are updated every time the arrows are pressed. And using a scrollbar is a little bit tricky.the only thing more I could ask for is a scroll bar that can work with the mouse wheel.
selgin:
It's been a real time saver for me!this software will be very useful in big projects.
¡De nada!muchas gracias, amigo.
heyvern:
It's a programming language, similar to RealBasic. I chose to make it in Visual Basic because it faster to make a program with it, and I really needed this tool. I am planning to buy in the future RealBasic or PureBasic, to make Mac and Linux versions of this program.What exactly is Visual Basic and is there a similar type of thing for the Mac?
It would seem to me that the 'create thumbnail' option would be the only update needed. I wouldn't expect it to update everytime I scroll. Like thumbnails for anything else, you have to 'refresh thumbnail' for it to update.Instead, there are only nine thumbnails which are updated every time the arrows are pressed.
But I'm no programmer. Just suggestions.
It's still a great app as it is!
Your program looks nice! Still need to try it out.v_aviles wrote:I am planning to buy in the future RealBasic or PureBasic, to make Mac and Linux versions of this program.
I love PureBasic as much as AnimeStudio. I've been using PureBasic for about 5 years now. There's a few programs that I couldn't do without and PureBasic and AnimeStudio are just 2 of them. It's just one of those programs you come across and you know there's no other to compare. But what ever you choose, happy programming.
