Layer opacity preview is incorrect
Multiple shapes overlapping on a layer, each shape is 100% opaque, no transparent colors. Transparency is set to true in the display settings.
In preview setting the layer opacity will display each shape as if it was transparent allowing underlying shapes to show through. This is incorrect. This is the bug. The whole layer should be transparent but not the individual shapes. Each shape is 100% opaque and should completely hide any shape below it. The layer as a whole has opacity but this should not effect the display of each shape.
Now we do a final render. The final render is correct. Each shape fill color is opaque over any underlying shapes but the whole layer is rendered at a lower opacity.
Technically this bug is not a deal breaker. You get the results you should but only in the final render. It can be confusing though if you don't know about this preview anomaly.
Yeah, not a deal breaker, but as annoying as the other preview/render discrepancies. I could see this one being trouble though.
I only just now realized that I had avoided using this layer opacity technique because my preview was incorrect.
Stupid me... I didn't follow my own advice of always rendering to check output.
