I am REALLY stuck here! I am trying to create a handwriting effect in AS using the layer trail script. How do I set the line thickness for the layer trail before the script is run??? I've tried to adjust the line thickness afterwards but I get crazy results. Is there anyway to set the line thickness before I run the script?
Thanks
D.K
Layer Trail Line Thickness
viewtopic.php?t=5816&highlight=layer+trail
Check this out. It says you need to 'draw' a circle that will work as your 'brush'.
Thanks synthsin75. That's actually the tutorial I followed.
The problem is that there is no way to set the line thickness of the layer trail in the layer trail script settings.....
HEY!I wonder if someone on the forum can improve this script???
I did find a workaround though....if you reduce the size of the vector layer before you run the script the line thickness will increase...but this is all a bit of guesswork but good enough to get me out of trouble.....thanks for responding.
Cheers
D.K
Cheers
D.K
Mmm, that's an odd script. The first time I tried it I just happened to increase my line size to 5 before I created my circle brush. This actually made a size 5 trace, but testing it I found that if you change the line size after creation, only the initial size is traced.
Also, is there any way to change the trace color?
Yes...I have noticed! You have been very helpfull to the whole forum and my own questions too and I thank you very much for that indeed.
Re that layer trail script: It would be helpfull to be able to set the line thickness from the layer trail settings dialogue box I think. Wonder how difficult that would be to implement scriptwise?
D.K
D.K
