What's the best screen capture software?
Hi.
Jus wondering what other people thoughts were on the best screen capture software for creating tutorials?
Cheers
D.K
Cheers
D.K
For the Mac, definitely, Snapz Pro X, although for quickies, iShowU, is a favorite, because it doesn't use after-take encoding, like Snapz Pro X. Many screencasters (video podcasters, using video screen captures as a medium, instead of live video) use Snapz Pro X, because of superior quality of the output.
- Víctor Paredes
For a linux user I think that gtkrecordMyDesktop is the best.
Also there are other tools that do similar job.
My 2 cents
My 2 cents
I have some tips for you. Because catching the whole screen at 30 frames per second is very processor intensive, I suggest you lower both your screen resolution (e.g. 800 x 600, or as low as the application permits) and your frame rate (e.g. 10 fps). Furthermore, as you're going to use a video codec, you should set the key frame rate fairly high, e.g. one frame every 480 frames. This saves tremendously on the file size.
I would also create/use a separate user account and wallpaper for the screencasts, so you don't have to show your personal stuff to the world.
