I only posted something yesterday but i have run into another problem.
I am animating my bones, but they are not starting the animation in the frame i start it in. It starts it right from the start and i dont want that.
Can anyone help me?
Thanx to anyone that does
CrAzY Dan
15 year old Anime Studio user...
27/12/06: Im back and ready to get creating again!!
The way kayframes work is that when you set a pose, Moho will move the object from the last keyframed pose to the next one. So, if you set a bone's position at frame 10, Moho will move that bone gradually (during frames 1..9) from its original position at frame 0 to the new position at frame 10.
If you want a sudden move at frame 10, you can do two things:
1) Before setting the pose at frame 10, add a keyframe at frame 9 that is identical to the keyframe at frame 0. That way, there will be no motion between frames 0 and 9, and frame 10 will move suddenly. To add a keyframe like this, right-click in the timeline at frame 9 and select "Add Keyframe".
2) You can also tell Moho to make it a sudden motion at frame 10 instead of gradual between 0 and 10. To do this, right-click on the keyframe at frame 0 and select the "Step" interpolation mode.
