Animated Layer Order - group layers inside a switch broken
You can not animate the layer order of bone layers inside a switch layer.
The keys are created properly in the layer order channel but the layer order animation does not work. If you drag the bone layer outside of the switch the layer order animates properly.
To clarify... the layers INSIDE the bone layer INSIDE a switch won't animate layer order until you drag it out of the switch layer.
Confirmed. The layer order changes, nested in a switch layer, make keyframes on the layer order channel, but like 5.5, these are not stored but change the entire document.
Springymajig
Post by Springymajig »
Hmmm... I just discovered this problem too. Of course... one way around it is to turn on and off the visibility of the appropriate layers but that's not as convenient as the one-click key framing of a switch layer... all those little things add up after a while
