HELP!!!
JESUSfreakPUNK
HELP!!!
Post by JESUSfreakPUNK »
I feel like a blonde here, but---
I can't figure out how to turn the outlines off!!!
I can see that the "enable outlines" button is checked, but I can't uncheck it!!!
It's grayed out. I can't touch it....
HELP?!?
Alix
You can only disable it after you've applied a fill to a shape. Search the forum. There are many ways to get around having to uncheck it every time you fill a shape.
there is a script wrote by rhoel (if i remember well) for make that.
JESUSfreakPUNK
Thank you for your help all!
Re: HELP!!!
JESUSfreakPUNK wrote: I can see that the "enable outlines" button is checked, but I can't uncheck it!!!
You have to select a shape to change the outline. What I've found that is confusing is that if you change a shape's stroke thickness and hit return it deselects the shape. You have to select it again to change it.
