how can I...bone pro...
mohsen123
Post by mohsen123 »
hey every-one:
how can I fix a bone with a picture @ frame 0 to act with each other in other frames?
Rasheed
Post by Rasheed »
Please, explain more. This is too cryptic. What do you exactly want to accomplish?
mohsen123
Post by mohsen123 »
we can create a bone only in frame 0.ok? so the related picture can not be match & fix to it in other frames so I cannot move whole picture(or group) same az bone,they r seprated so the point of move isn`t fixed with the picture...
PLEASE HELP ME!!!! :?:
This is totally incoherent. We still don't know what your problem is! If you can't explain it correctly, post up your .anme file so people can take a look at it...
mohsen123
Post by mohsen123 »
well it`s so obvious...
I want to bone a picture,they r ok on frame "0" but when I move the picture in other frames,the bone won`t follow the picture so the motion form will destroy because of distance between the bone & picture.
ok?
Ah, I think I can guess what you ask for.
Objects in AS need to be created in frame 0 and will exist for the entire duration of the file. You can only switch them invisible/visible.
The connection between objects must be created in frame 0 as well. It can not be changed in other frames.
I guess that you didn't bind your object to a bone properly. Go to frame 0.
1. Put every layer that you want to control by bones into the bone layer. (It will appear as a sub-layer under the bone layer.) See tutorial 3.1 for reference.
2. If you don't use flexible binding (which is the default) you either use region binding or layer binding. Layer binding is described in tutorial 4.1. If you use this, you need to press the space bar to make the binding permanent.
3. In any case, use the Bone Manipulate Tool (Z) to test inside frame 0 wether your binding works correctly.
(Note: These tutorials badly need to be rewritten!)
mohsen123
Post by mohsen123 »
sorry but it doesnt work either,the object is seprating from bone even after pressing space bar in other frames so the rotation point of object change by the distance.
& we can set which object come in the certain frame & out.so I dont have the object @ the frame"0".
Rasheed
Post by Rasheed »
I still can't understand you. If, for some reason, you can't write proper standard American or British English, please give us an url where we can download your Anime Studio project (.anme) file. This makes talking about your problem easier.
Rhoel
Post by Rhoel »
I agree with Rasheed on this one - the abbreviated English and lack of related punctuation makes this difficult to comprehend. As a result, I cannot reproduce the problem you have.
Since you are using attached images, you'll need to zip the anime file and dump it online somewhere.
I suspect you are attempting to move the image and not the bone, or that the wrong bones tool/s are being used. Bones can be a sod on occasions, especially on the binding - took me a while before I was happy with how to get the best out of it.
Folk here are glad to help out IF we understand the problem.
Hi mohsen123,
I think I got it.
Bones acts like a skeleton of a puppet. At frame 0 you set up your bones and your shapes of the pupet. Later at any frame you usually would move your bones only and perhaps you do some point animation but maintaining the main distance from of the shapes to the bone. The point motion of any shape that is bound to a bone is relative to the bone so if the bone translates rotates or scales all the points of the shape would follow (all the bound points). But you can make some point deformation of the shape (perhaps to figure some perspective deformation or other issues)
Look at this example:
http://es.geocities.com/carloslopezgonz ... e.anme.zip
there you can find a shape with an cycle point animation and how the animation of the bones makes it to follow.
Remember, point animation is always relative to bones coordinate system if the shape is bound to the bone(s). ONLY if the point is unbound (or bound to none bone) its point animation is relative to the global coordinate system.
For more information I recommend to read this:
http://www.lostmarble.com/moho/manual/bone_layers.html
and this:
http://www.lostmarble.com/moho/manual/t ... index.html
Cheers.
dicle
Post by dicle »
I m lokkıng for back ground that ı can buy
