Problems with interpolation Switching Layers
Astrocloud
Greetings,
I am trying to do a simple 45 degree headturn using Interpolation and switch layers.
All of the layers are interpolating correctly except for two. One of the layers (whisker layer) is very simple. The other has a few more points on it but both layers are modified layers of the original and have the same number of points.
I'm not really sure what is going on.
The file is here:
http://www.telepathic-studios.com/kitty2.anme
Thanks in advance.
The file is here:
Thanks in advance.
What's going on is those layers DON'T have the same number of vertices.
For example, if you look at the "whiskers" layer (the top layer of the whiskers switch) you'll see that at the top of the frame there are two line segments (one containing three vertices, the other two) that are not present in the 45 degree whistker layer (you may need to zoom out to see them -- select the vertice select tool and they will appear).
If you delete these then the whiskers will then interpolate correctly (they are also present on the top nose layer as well)
Astrocloud
Astrocloud
Astrocloud
Perhaps this is not clear..Astrocloud wrote: The file has been updated from the previous one.
Astrocloud
