Debug Mode on Search?
VidE
Post by VidE »
I'm not sure if this is the right place to post this, but everytime I try to do a search, I get a Debug Mode error. I'm on a Mac, running OSX 10.4.9 and I turned off mySQL, just in case there was some sort of PHP conflict. Still no go.
Is it me or the forum and if it is me, any suggestions for a fix?
Ashe Raven
Post by Ashe Raven »
It's the forum because it's doing the same everytime I post a messege
empty
test...
Post by empty »
i've been having problems, so this is a test.
empty
test
Post by empty »
test
empty
test
Post by empty »
test
dueyftw
Post by dueyftw »
testing
Dale
dueyftw
Post by dueyftw »
I'm wondering if someone fix the forums?
Dale
dueyftw
Post by dueyftw »
Nope.
Dale
VidE
Post by VidE »
I can post, sometimes, but cannot use the search function at all. I get an error message:Could not obtain matched posts list
DEBUG MODE
SQL Error : 145 Table './lostma2_phpbb1/phpbb_search_wordlist' is marked as crashed and should be repaired
SELECT m.post_id FROM phpbb_search_wordlist w, phpbb_search_wordmatch m WHERE w.word_text LIKE 'bone' AND m.word_id = w.word_id AND w.word_common <> 1
Line : 341
File : search.php
This happens on both a Mac and Windows computer and has happened only recently.
Rhoel
Post by Rhoel »
VidE wrote:I can post, sometimes, but cannot use the search function at all. I get an error message:Could not obtain matched posts list
DEBUG MODE
Line : 341
File : search.php
Whoa, the SQL error is a worry - it means the database is screwed up! I note too that animatorguy who joined 25 Mar 2008 has 16777207 posts ... get some sleep sometime son ;-)
I trust mike will have a look at this soonish.
Rhoel
