I was talking to a collegue today and he asked if AS could output High Definition resolution. Not just the widescreen aspect ratio but the High Def pixel resolution. I was'nt sure how to answer this but maybe someone on the forum could shed some light. Is there a need for a High Def resolution setting in the next version of AS?
D.K
High Def Resolution
- Barry Baker
Color Space
ASP seems to be able to render in any resolution you want. However, the color depth is, as far as I can tell, is only available at 8 bit per channel. The color space used by ASP is sRGBIEC61966-2.1. This doesn't seem to be any kind of drawback for renders that essentially look like cel animation.
16 and 32 bit per channel imaging is designed to maintain the clarity of beautifully shot motion picture film and HD equivalent footage. To see the TRUE tonal range of such footage, you'll need a professional HD monitor that's about $4600 for a 22 in. screen. These monitors are made for production facilities that work on feature films.
So, we have the resolution, but not the color depth of true HD.
