Playback speed
Locked
rylleman
Playback speed
Post by rylleman »
I just came across an annoying thing with moho regarding playback speed.
I have a quite large project so I rarely get playback speeds over 15fps but now I tried the skip frame option and I suddenly got a playback speed of 30fps although my project is in PAL and should play at maximum 25fps. It seems that Moho doesn't take any regard to the project settings when it playbacks your animation.
Lost Marble
Post by Lost Marble »
Which version of Moho are you using, and which operating system?
I need to know the exact version of Moho - you can check by using the Help->About Moho menu command.
rylleman
Post by rylleman »
v. 5.0.7 on winXP.
Lost Marble
Hmm, I was hoping this was related to a timing problem on older versions for Mac OS X - I'll have to check into this some more to see what's going on.
nobudget
Post by nobudget »
Just did a little test with an empty project set to a really small size to get the maximum framerate. Frame "0" getscrazy and screws up the average rate but then it evens out to exactely 25 fps and doesn't go faster. Version 5.0.4 on WinXP.
Hope that helps someone,
Reindert.
www.nobudgetvideo.com
Locked
