i'm trying to put a vulcano (one layer) crossing from under the sea (another layer) but i didn't had full success, the vulcano jump from below the sea to above.
anyone can help? i want the vulcano cross the middle of the sea.
Crossing layers
with two vulcanos (2 layers) seams to not work, the vulcanos jumps to beside the seaHiddicop wrote:Actually this is one of mohos biggest problems. But in this case it can be solved. You need two identicle volcanos. One you mask so it is hidden when under the water, and the other one is revealed under the water. I hope I understood the problem, and I hope my solution is understandebul.
10x for the help....
can i send it to you by email?Hiddicop wrote:It jumps to beside the sea? Hmm... Could you post a file, or some images, so we can see more clearly what the problem is?
- Lost Marble
You can send it to me by email if you want: support@lostmarble.com
