Is there any way to do this?
Can translating a layer by bone binding be made to work like the translate layer tool is used in LM's warp field trick in this thread? I'm assuming not, since layer binding is the same as binding all of the points in the layer.
You've got it. The points of a layer have to be flexi-bound in order for that to work. As you said, binding a layer binds all the points.
Thanks Vern. I thought so. Luckily I may have come up with another solution.
