Exporting Problem!
cafejava
Exporting Problem!
Post by cafejava »
This has been talked about before, but I need help and will give info. I use a mac leopard operating system. I use Anime Studio 5.
When ever I try to export a movie, it will quit. It even quits on 48 frame movies! I've tried exporting in SWF and Quicktime! What is going on? How can I fix this?
Use the batch renderer.
cafejava
Post by cafejava »
slowtiger wrote:Use the batch renderer.
where is it? How do I get to it?
File > Batch Export.
cafejava
Post by cafejava »
slowtiger wrote:File > Batch Export.
I only see export. I don't use pro so batch export is probably on pro only
kittyvibe
Post by kittyvibe »
I have this problem as well, tried the batch export and the program closes promptly. any new advice?
Rasheed
Post by Rasheed »
This is probably an incompatibility with the latest QuickTime update. The issue seems to be less when you use None as the compression type. So, use Batch Export and None as compression type.
This needs to be fixed.
Rasheed
Anime Studio Pro render droplet for Mac OS X
Post by Rasheed »
I have a temporary solution, that hopefully works (it worked for me).
I have written an Applescript droplet for rendering Anime Studio Pro files, outside the Anime Studio graphical user interface mode. The droplet assumes you have Anime Studio Pro installed in the normal location (/Applications/Anime Studio Pro/). The application is tested with Anime Studio Pro 5.5, on Mac OS X 10.5.2 Leopard, and is supplied as-is.
You can download the droplet as a ZIP archive, unzip it, and put it wherever you want to. I put it in the Anime Studio Pro folder. Create a shortcut on the Dock (by dragging the icon on the Dock), so you can easily access this utility as an application.
Just drop one or more .anme files on the droplet, and it will convert your files to Quicktime video in the same folder as the .anme files.
Here is the script source code:
on open theItems
	set ASP to "'/Applications/Anime Studio Pro/Anime Studio Pro.app/Contents/MacOS/Anime Studio'"
	repeat with x in theItems
		set theFile to (quoted form of the POSIX path of x)
		set theCmd to (ASP & " -r " & (theFile as string))
		do shell script (theCmd)
	end repeat
end open
If you want to change the render options (you will need to write a new AppleScript for that), please have a look at this topic: PS As is usually the case, this is a small hack that is very useful for most (Mac) users. I just like it that way ;)
slice11217
Post by slice11217 »
Rasheed wrote:This is probably an incompatibility with the latest QuickTime update. The issue seems to be less when you use None as the compression type. So, use Batch Export and None as compression type.
Is this in reference to the recent quicktime version 7.4.1, or version 7.4? I'm only wondering because Apple claims to have resolved "compatablity issues with third party software" with the .1 version.
Rasheed
Post by Rasheed »
I had Apple's own screen saver crash on me this afternoon.
There seems to be some issues with core Animation.
I must mention that I have some third-party haxies installed, which could cause problems as well.
BTW I don't know if AS is Leopard ready. I guess not, because it hasn't been updated for a long time, and most software had to be upgraded to work reliably with Leopard.
