How to export animated noise to Flash MX ?
Jean_R
Post by Jean_R »
Hello everyone,
I experience some problems with animated noise applied to shape. The exported file is played correctly by my internet navigator but when I want to import it into Flash MX (not 2004) the result is not correct at all >
the file exported from AS
the (ugly) result in Flash
Is animated noise to add in "no export feature" ?
Jean_R
Partially Solved [flash issues] woot-woot !!
Post by Jean_R »
Importation from AS to Flash MX causes corrupted files (see first post), in worst case crashes directly the soft.
Obviously I noticed that files that Flash couldn't import were well displayed into my web browser so by flash player. I tried a "loadmovie" in order to include AS file without importation and it works !!
Not perfect (no preview in stage) but I can use Flash in order to enhance AS swf files interactivity and manage scenes.
Here an exemple, it makes flashes while clips start at each load because I'm a newbie (and this forum is not for flash problem's users:)) but as you can see, it is loaded properly even the animated vector noise.
Cheers :D
