REVERSE KEYFRAMES!!
REVERSE KEYFRAMES!!
Well, I said that I'd post it here, and here is it... CIAO!
  ...Maybe with script?
						One other option would to allow you to use the Rescale Keyframes command (if it would let you). For example, Rescale Keyframes 10 - 20 to 20-10 to reverse the keys. I tried it once a while ago and it made Moho sick, don't recall if it locked up or crashed. But that would seem to be an easy place to allow you to do this without a lot of extra work.
While I'm at it, especially if this could be worked out, would be a "Rescale" button in the Timeline window. I find myself using it a fair amount, and that little bit of extra accessibility wouldn't hurt at all. Thanks.
--Brian
--Brian
My input: I think it would be simple if it was just a seperate command rather then done within the Rescale Keyframes Menu.
									--Scott
cribble.net
						cribble.net
				LittleFenris
