how do I make animations past frame 72???
hoqboy
Post by hoqboy »
ive made an animation, but when i play, it stops at frame 72, where its highlighted. help's appreciated
-Rafi, 13
go to project settings, and put zero as end frame (save as default if you want). your animation will be unlimited.
fiziwig
Post by fiziwig »
If you are using standard AS, not PRO, you have a maximum of 3000 frames per file. Set the end frame to any number less than 3000.
Setting the ending frame to 0 in the standard version gives you NO frames of animation.
--gary
fiziwig wrote:Setting the ending frame to 0 in the standard version gives you NO frames of animation.
no, the animation will last until the last keyframe you add. if there is no keyframes, the animation will last zero. :wink:
fiziwig
Post by fiziwig »
You're right. I stand corrected.
--gary
hoqboy
Post by hoqboy »
thanks a ton :)
-Rafi, 13
cartmanblues
Post by cartmanblues »
Yea I was about to ask this too! Thanks!
