how do I make a new keyframe
without doing anything with the animation... jus make a random frame in the timeline... got AS yesterday =D
-Rafi, 13
- Víctor Paredes
You're right -- but couldn't a new keyframe be created, by default, with a keyboard shortcut on the current tool's timeline (ie Translate Layer, or Color Fill) ?slowtiger wrote:There can't be a keyboard shortcut because AS doesn't know which timeline you want to create a key in without the user clicking at it.
Yes, it would require modifying each of the tools. Not a bad idea. Isn't there a script that "almost" adds keys for every channel/layer? Or is it just points? I suppose you could pull out the relevant chunks of that script into different functions and make a "utility" script. Each tool would use the same key combo but it would call a different function depending on which tool is selected.cableon wrote:You're right -- but couldn't a new keyframe be created, by default, with a keyboard shortcut on the current tool's timeline (ie Translate Layer, or Color Fill) ?slowtiger wrote:There can't be a keyboard shortcut because AS doesn't know which timeline you want to create a key in without the user clicking at it.
Oh how I hope there are just a few extra scripting features in the new update.
I have the script for a tool that creates keys for everything -- I modified it because the default key type is step (and I wanted smooth) and I added a keyboard shortcut so all I have to do is press a key to key everything, no matter where I am.
Comes in extremely useful -- the script was part of a set of other scripts (don't remember which person wrote it, but initials are JS).
