Change animation length
VelcroMan
Post by VelcroMan »
Hi, I'm very new to Anime Studio. And i wonder how i can make my animations longer than 72 frames (change the length of the animation).
Thanks in advance :P
There are two ways. The quick way -- alt-right click on the blue bar above the timeline. The slow way (and the best if you are planning a long animation) is to click on "File" then "Project Settings" -- up comes a panel where you can type in the new end frame.
VelcroMan
Post by VelcroMan »
jahnocli wrote:There are two ways. The quick way -- alt-right click on the blue bar above the timeline. The slow way (and the best if you are planning a long animation) is to click on "File" then "Project Settings" -- up comes a panel where you can type in the new end frame.
Thank you :)
Maybe i should start a new thread, but.. Can i have more than one soundtrack?
in project settings, if you chose 0 as animation end, the animation will last until the last keyframe. i have this configuration as default.
VelcroMan wrote:Maybe i should start a new thread, but.. Can i have more than one soundtrack?
no, you can't.
but there is an old tricky script of 7feet which let you to have more than one soundtrack, but i never have used it.
