Hello,
I'm probably missing something very obvious, but I can't seem to find the solution. I am using the linux version of moho, and am trying to export still frames in png format. I'm using the default 24 frames per second setting, but am only getting one frame per second. I have 60 frames in my test, and I was expecting 1440 (60 * 24) png images. However, since there are only 60 png images, it looks like it's only doing 1 frame per second.
Thanks for any help!
exporting still frames
- Lost Marble
It sounds like you're confusing frames and seconds. Like you said, you have 60 frames in your test, and 60 frames were exported. It sounds like Moho is doing the right thing.
Running the math in reverse, if you have 60 frames and 24 frames per second, the duration should be 60 / 24 = 2.5 seconds worth of animation.
