Parenting cross-constraint example
I made this up for my own reference, but maybe someone else could find it helpful. These are examples of using bone parenting to make one constraint input (translate,rotate,or scale) output to a different constraint of another bone. I think these will help minimize control points on a rig.
Another benefit is that they don't require scripting, which may be of interest to non-Pro users.
new link
Let me know if anyone finds this useful.
new link
Maybe you need to upload the file again. It might have gotten "scrambled".
I fixed it using a text editor but I had to delete one of the layers. Something happened to one of the notes layers and it caused the file to fail to open. If you put "funky" characters in a note layer text it can sometimes trash the file.
I checked it out and it looks like you have discovered Genete's "Springy Bones"! along with a few others.
Genete's creation of those "springy bones" a while back was my inspiration for a TON of scripts and some crazy head turn experiments. I was AMAZED by it when I first saw it. He used that for "circular" translations because the bone at the end translates based on rotations. You get a "perfect" back and forth translation. (I ended up with a head turn with 100's of bones which is why I wrote those scripts to have ONE bone instead of 3 for a similar effect)
There is a thread about head turns in tips and techniques (3 bone head turn?) that uses the "scale/translation". Put the scaling bone on the opposite side translates a bone in "reverse" direction to create a "turning" effect. It was incredibly effective.
This is a fantastic reference for all of those relationships. Great to have it all in one file.
p.s. Let me know if your copy of this file is also "broken". I can send you the fixed one. I am pretty sure it is due to funky text in the notes layers. I experimented with notes and was able to "break" files if I typed in strange characters.
Here is the fixed file:
http://www.lowrestv.com/moho_stuff/foru ... aints.anme
I had to delete a notes layer. The part that was "missing" at the end.
Thanks Vern, mine works fine. I'll try again. If not I'll just copy your link.
And yeah, I meant to give you credit Genete. That's by no means my discovery. I figured the heavy scripting folks would just ignore it. Like I said, non-Pro users may find some of those rigs useful.
Not to mention myself, until either I learn how to utilize more scripts or someone writes them as tool or menu scripts. (hint, hint)
Yes that is correct. An AS file is just like an HTML document. The images in it are just "links" they aren't contained inside it.synthsin75 wrote:While I'm thinking about it, is the only way to include an image layer to zip it up with the .anme file?
If that is the case then it is possible the file got "chopped" or corrupted during upload. I downloaded it several times just to make sure it wasn't a bad download.Thanks Vern, mine works fine. I'll try again. If not I'll just copy your link.
I would try uploading it again from your end first. I checked and there are no "funky" characters in the notes layers that are working so I doubt it was that. Probably something happened when you uploaded it.
