lip syncing more then 1 character using switch data/as
Since AS (as far as I know) only lets you put 1 sound track in, how do you or can you assign which character to react to what voice?
Did you read the instructions on Papagayo (assuming you are using that for your lip sync)? You can generate multiple voices -- save each out as separate .DAT files that load into the appropirate switch layer of the character in question.
It works really, really well (and so easy to use I'm not sure why anyone would want to do it any other way).
