Depends on where you have SceneSelector installed (and perhaps which button you're using, there are a few I made; I'll assume x_app). The easiest way to find the path, if you don't remember where you installed it (on XP), is to right-click the shortcut and select properties. Copy the target path.What is the right path to start Scene Selector from the button on Anime Studio?
Scene Selector
I know where the program are installed, the problem are another.
I've installed the button on Anime studio and when I press it, a DOS windows appears for a few seconds.
Nothing appens and the windows closes saying "Invalid command"
I have to insert the program path on the line in the _tools_list.txt?
You have to open the script, syn_x_app.lua, in a text editor like Notepad. Find the section below this:
The first one will be:
Just put your actual path here, making sure that it is surrounded by "\" and \"" as shown.
One of these days, I'll include a UI for finding the programs and automatically assigning these paths.
-- Application Paths
-- Edit these according to your system
-- ***************************************************Code: Select all
SceneSelector = "\"C:\\Program Files\\Anime Studio Scene Selector\\SceneSelector.exe\""One of these days, I'll include a UI for finding the programs and automatically assigning these paths.
v_aviles will have to help you with that, but I'd try reinstalling it. I updated from an earlier version, so if they're still up, you might try installing one of those and then just replacing the .exe file to update.
v_aviles,
Love the improvements. I only have one request. Would it be possible for Scene Selector to store all of its backups and thumbs in the installation folder? I keep deleting the thumbs folder from my desktop after I've accidentally navigated to it.
p.s. Any reason the scroll bar flashes?
v_aviles,
Imago:
It is a very strange error. I've done some tests and still don't get that error displayed. I even verified the code and found nothing. Are you using an external drive or flash drive to store your Anime Studio files?
synthsin75:
synthsin75:
I have no idea! But it's not the first time I write a program in Visual Basic and the scroll bar flashes...p.s. Any reason the scroll bar flashes?
I could make another upgrade in which the backups and thumbs folder can be specified instead of creating and using sub-folders in the folders in which the animations are stored.Would it be possible for Scene Selector to store all of its backups and thumbs in the installation folder?
The program was installed on the default path.
Now I've moved it in my AS project folder on a external USB HD, in this way I don't need change directory.
The error appears in both cases...
P.S.
I work under Windows Millennium Edition because some graphics utilities crashes on XP and Vista... The OS are the trouble?
P.S.
Scene Selector update
*** Update ***
Sometimes, a thumbnail was not created. This version solves that bug:
http://www.mediafire.com/?741dcg7azbfry8b
Very well! I was looking for it from ages! Thanks, V_Aviles!
P.S.
It give me the same "run-time error 53, File not found" when I try to create yhe thumbnails, as the older versions... And everytime I run the program again, it will create the thumbnail once, then it crashes at error 53...How it comes?
P.S.
