Keyframe many layers at once?
Touched
Re: Keyframe many layers at once?
Post by Touched »
I wouldn't know about those things, since I use 5.6, so I hope someone else will speak up with that answer.
Touched wrote:I've reuploaded the key skeleton, key all, and my own "key none" variation to my Dropbox account.
https://dl.dropbox.com/u/27739431/Anime ... scripts.7z
These work in version 5.6, which is the version I'm still using.
Thanks, Touched -- still using 5.6 too, although I'm looking on with envy at the 'smart bones' feature, the first time I've considered upgrading. It's a lot of spondulicks if you're just a hobbyist, though...
cekilinbendoktorum
Post by cekilinbendoktorum »
It works on anime 9 but i want to key just a character or selected layer not all document how can i do that any ideas ? :?
cekilinbendoktorum wrote:It works on anime 9 but i want to key just a character or selected layer not all document how can i do that any ideas ? :?
Freeze pose (ctrl+F) add keyframes for all the bones in the angle channel. If you have added keyframes for scale or translation at least once in the document, it will add keyframes for that channels too.
It works the same for vector layers (translation, width, curvature).
cekilinbendoktorum
Hi selgin, thanks for the tip... The goal is keyframe a character (with sublayers,bones,vector,swtich,groups that in the character). And add keyframes to every keyable things. This script does that perfectly anyhow it keyframes entire document. And it's a waste of time. Which part of this script must change ? Can you give and idea ? I just want to the keyframe the selected layer.
-- Provide Moho with the name of this script object
ScriptName = "JS_key_all"
JS_key_all = {}
function JS_key_all:Name()
	return "Key All"
end
function JS_key_all:Version()
	return "1.1"
end
function JS_key_all:Description()
	return "Key all channels in all layers!"
end
function JS_key_all:Creator()
	return "Julien Stiegler"
end
function JS_key_all:UILabel()
	return("Key All")
end
-- The guts of this script
function JS_key_all:OnMouseDown(moho, mouseEvent)
	self:key_all(moho, mouseEvent)
end
function JS_key_all:Run(moho)
	self:key_all(moho)
end
function JS_key_all:key_all(moho, mouseEvent)
	JS_key_all.verbose = true
	JS_key_all.initLayer = moho.layer
	JS_key_all.currentFrame = moho.frame
	moho.document:PrepUndo(moho.layer)
	moho.document:SetDirty()
		--BONE layers : key every layer's layer specific channels
		if( aLayer:IsBoneType() ) then
			moho:SetSelLayer(aLayer)
			local skel = moho:Skeleton()
			for j = 0, skel:CountBones() - 1 do
				local bone = skel:Bone(j)
				bone.fAnimPos:AddKey( self.currentFrame )
				bone.fAnimAngle:AddKey( self.currentFrame )
				bone.fAnimScale:AddKey( self.currentFrame )
				if(self.stepMode:Value()==true) then
					bone.fAnimPos:SetKeyInterp(  self.currentFrame , MOHO.INTERP_STEP , 0.0, 0.0)
					bone.fAnimAngle:SetKeyInterp(  self.currentFrame , MOHO.INTERP_STEP , 0.0, 0.0)
					bone.fAnimScale:SetKeyInterp(  self.currentFrame , MOHO.INTERP_STEP , 0.0, 0.0)
				end
			end
		end
		--VECTOR layers : key every shapes AND mesh points
		if (aLayer:LayerType() == MOHO.LT_VECTOR) then
			local aMesh = moho:Mesh()
			for j = aMesh:CountShapes() -1, 0, -1 do
				local shape = aMesh:Shape(j)
				shape.fMyStyle.fFillCol:AddKey( self.currentFrame )
				shape.fMyStyle.fLineCol:AddKey( self.currentFrame )
					shape.fMyStyle.fFillCol:SetKeyInterp(  self.currentFrame , MOHO.INTERP_STEP , 0.0, 0.0)
					shape.fMyStyle.fLineCol:SetKeyInterp(  self.currentFrame , MOHO.INTERP_STEP , 0.0, 0.0)
				end
			end
			for k = aMesh:CountPoints() -1, 0, -1 do
				local aPoint = aMesh:Point(k)
				aPoint.fAnimPos:AddKey( self.currentFrame )
					aPoint.fAnimPos:SetKeyInterp(  self.currentFrame , MOHO.INTERP_STEP , 0.0, 0.0)
				end
			end
		end
		aLayer:UpdateCurFrame()
	end
	moho:SetSelLayer(JS_key_all.initLayer )
--	moho.layer:UpdateCurFrame()
--	moho:UpdateBonePointSelection()
--	moho:UpdateSelectedChannels()
	moho:UpdateUI()
--	moho:Redraw()
end
--add an auto-step
-- void SetKeyInterp(when, interpMode, val1, val2)
-- fAnimPos:SetKeyInterp(  self.currentFrame , INTERP_STEP , 0, 0)
JS_key_all.STEP = MOHO.MSG_BASE;
function JS_key_all:key_all_recursive(moho, currentLayer)
	local lInitLayer = moho.layer
	s
				end
			end
		end
				end
			end
				end
			end
		end
--	end
	moho:SetSelLayer(lInitLayer )
end
function JS_key_all:DoLayout(moho, layout)
	self.stepMode = LM.GUI.CheckBox("step mode", self.STEP)
	layout:AddChild(self.stepMode)
	self.stepMode:SetValue(false)
end
Lúthien
Post by Lúthien »
I'm glad to report that they still work in 11.1 - great work, thanks! It's a time-saver :)
reniad nu elin luin
