Keyframe many layers at once?
Re: Keyframe many layers at once?
I wouldn't know about those things, since I use 5.6, so I hope someone else will speak up with that answer.
Thanks, Touched -- still using 5.6 too, although I'm looking on with envy at the 'smart bones' feature, the first time I've considered upgrading. It's a lot of spondulicks if you're just a hobbyist, though...Touched wrote:I've reuploaded the key skeleton, key all, and my own "key none" variation to my Dropbox account.
https://dl.dropbox.com/u/27739431/Anime ... scripts.7z
These work in version 5.6, which is the version I'm still using.
cekilinbendoktorum
It works on anime 9 but i want to key just a character or selected layer not all document how can i do that any ideas ?
Freeze pose (ctrl+F) add keyframes for all the bones in the angle channel. If you have added keyframes for scale or translation at least once in the document, it will add keyframes for that channels too.cekilinbendoktorum wrote:It works on anime 9 but i want to key just a character or selected layer not all document how can i do that any ideas ?
It works the same for vector layers (translation, width, curvature).
cekilinbendoktorum
Hi selgin, thanks for the tip... The goal is keyframe a character (with sublayers,bones,vector,swtich,groups that in the character). And add keyframes to every keyable things. This script does that perfectly anyhow it keyframes entire document. And it's a waste of time. Which part of this script must change ? Can you give and idea ? I just want to the keyframe the selected layer.selgin wrote:Freeze pose (ctrl+F) add keyframes for all the bones in the angle channel. If you have added keyframes for scale or translation at least once in the document, it will add keyframes for that channels too.cekilinbendoktorum wrote:It works on anime 9 but i want to key just a character or selected layer not all document how can i do that any ideas ?
ScriptName = "JS_key_all"
JS_key_all = {}
function JS_key_all:Name()
return "Key All"
end
function JS_key_all:Version()
return "1.1"
end
function JS_key_all:Description()
return "Key all channels in all layers!"
end
function JS_key_all:Creator()
return "Julien Stiegler"
end
function JS_key_all:UILabel()
return("Key All")
end
-- The guts of this script
function JS_key_all:OnMouseDown(moho, mouseEvent)
self:key_all(moho, mouseEvent)
end
function JS_key_all:Run(moho)
self:key_all(moho)
end
function JS_key_all:key_all(moho, mouseEvent)
JS_key_all.verbose = true
JS_key_all.initLayer = moho.layer
JS_key_all.currentFrame = moho.frame
moho.document:PrepUndo(moho.layer)
moho.document:SetDirty()
--BONE layers : key every layer's layer specific channels
if( aLayer:IsBoneType() ) then
moho:SetSelLayer(aLayer)
local skel = moho:Skeleton()
for j = 0, skel:CountBones() - 1 do
local bone = skel:Bone(j)
bone.fAnimPos:AddKey( self.currentFrame )
bone.fAnimAngle:AddKey( self.currentFrame )
bone.fAnimScale:AddKey( self.currentFrame )
if(self.stepMode:Value()==true) then
bone.fAnimPos:SetKeyInterp( self.currentFrame , MOHO.INTERP_STEP , 0.0, 0.0)
bone.fAnimAngle:SetKeyInterp( self.currentFrame , MOHO.INTERP_STEP , 0.0, 0.0)
bone.fAnimScale:SetKeyInterp( self.currentFrame , MOHO.INTERP_STEP , 0.0, 0.0)
end
end
end
--VECTOR layers : key every shapes AND mesh points
if (aLayer:LayerType() == MOHO.LT_VECTOR) then
local aMesh = moho:Mesh()
for j = aMesh:CountShapes() -1, 0, -1 do
local shape = aMesh:Shape(j)
shape.fMyStyle.fFillCol:AddKey( self.currentFrame )
shape.fMyStyle.fLineCol:AddKey( self.currentFrame )
shape.fMyStyle.fFillCol:SetKeyInterp( self.currentFrame , MOHO.INTERP_STEP , 0.0, 0.0)
shape.fMyStyle.fLineCol:SetKeyInterp( self.currentFrame , MOHO.INTERP_STEP , 0.0, 0.0)
end
end
for k = aMesh:CountPoints() -1, 0, -1 do
local aPoint = aMesh:Point(k)
aPoint.fAnimPos:AddKey( self.currentFrame )
aPoint.fAnimPos:SetKeyInterp( self.currentFrame , MOHO.INTERP_STEP , 0.0, 0.0)
end
end
end
aLayer:UpdateCurFrame()
end
moho:SetSelLayer(JS_key_all.initLayer )
-- moho.layer:UpdateCurFrame()
-- moho:UpdateBonePointSelection()
-- moho:UpdateSelectedChannels()
moho:UpdateUI()
-- moho:Redraw()
end
--add an auto-step
-- void SetKeyInterp(when, interpMode, val1, val2)
-- fAnimPos:SetKeyInterp( self.currentFrame , INTERP_STEP , 0, 0)
JS_key_all.STEP = MOHO.MSG_BASE;
function JS_key_all:key_all_recursive(moho, currentLayer)
local lInitLayer = moho.layer
s
end
end
end
end
end
end
end
end
-- end
moho:SetSelLayer(lInitLayer )
end
function JS_key_all:DoLayout(moho, layout)
self.stepMode = LM.GUI.CheckBox("step mode", self.STEP)
layout:AddChild(self.stepMode)
self.stepMode:SetValue(false)
end
I'm glad to report that they still work in 11.1 - great work, thanks! It's a time-saverTouched wrote:I've reuploaded the key skeleton, key all, and my own "key none" variation to my Dropbox account.
reniad nu elin luin
