Jaws
DarthFurby
http://www.errolgray.com.au/Jawsdemo2.anme
Here's a finished Jaws anme file, (outline only. add your own blood and guts!), using one main switch layer to control the sharks three sub layers. After point morphing the main shark file I divided it into 3xseperate layers just by cutting pasting the point data i needed from the main file for each particular move. Layer1-side, Layer 2-Turn, Layer 3-Swim. Now just apply the switch layers along the timeline and translate and scale the main switch layer to suit. This is all hand done from 2xphotos. No 3D objects were used just point dragging.
D.K
D.K
Jaws
Awesome.
DK u r great. I love it.
- Víctor Paredes
Here's a short movie test of the final shark anme file complete with colouring details.
http://www.youtube.com/watch?v=HbWA7vJBAS0
D.K
D.K
- Víctor Paredes
i saw the youtube file, it's amazing way using just vectors. the brights of the back looks wonderful. it's sad that you tube don't let me to see the video frame by frame.
did you change the .anme file?
i had a question about switch layers, but i hadn't time to write before, now i download the file again, and it seems to be different.
before you had several layers (two or three, i remember) inside a switch layer, right?
and the shark turning was one layer with this animated movement. well, i played with your file and i noted that the switch layer didn't work well, because the time in which you select to show the turning shark, should adjust to the turning cycle. if you create this keyframe in a wrong place, the movement didn't flow well.
it's hard to explain to me in english, i hope you understand. anyway, did you change the file or all i think i saw was an illusion?
did you decided to not use switch layers with this file?
Because everything is done with switch layers, the trick is to drag each actions switch layer keyframe along the timeline till you find the start frame of the action you're using. It takes a bit of tweaking but it's no big deal. If you wanted to make it easier to find the start frame of an action, just look at the amount of frames in the actions cycle and muliply this number till you get a start keyframe that's close to your insert point and drag the keyframe to this position. ie, if there's 27 frames in a cycle your keframe insert points for this action will be 1,,28, 54,80 and so on.
D.K
D.K
