Jaws
DK
Jaws
Post by DK »
Just thought I'd share this if anyone's interested. It took me about two hours in AS.
Cheers
D.K
J. Baker
Post by J. Baker »
Hmm, unable to see the image.
spoooze!
Post by spoooze! »
Nice water effect!
James 8)
p6r
Post by p6r »
Absolutely wonderful : the shark and the water effect !!!
ulrik
Post by ulrik »
Wow, that's very well done, I love the water fx
Mikdog
Post by Mikdog »
Very very cool.
DK
Post by DK »
Hey thanks for the nice comments. I'm doing some 3/4 views of it right now just with point manipulartion to see if i can get it to rotate in 3D smoothly using switch layers and interpolation.
D.K
MikeHart
Post by MikeHart »
Another example that an artist can do pro work inside AS!!!
Can you please explain that a little more? I can imagine a little the rotation via point manipulation. But how does rotating the layer in 3D get into this prozess? Sorry if I ask a newbie question.
MikeHart
Post by MikeHart »
And if you are bored, could you please make a tutorial about how you create such a picture?
DK
Post by DK »
I'll post an AS file shortly for you.
Cheers
D.K
DK
Post by DK »
http://ww.errolgray.com.au/Jawsdemo.zip
Here is a link to the file i'm working on. This is not true 3D but a way of faking 3D in AS. The way I approached this is to use two photo's of the animal you want to create as reference, one side and one 3/4 view (i just found them on the net).
Then in AS break the animal into 3 basic blob shapes, focusing on the general outline of the head mid and hind quarters. You'll see from the anme file that i've only finished work the first two shapes, head and mid section so far. Using the same number of points always I just manipulate them to form the first basic body shape that suits the first photo then drag the timeline along say ten frames and drag the points so that they all form the shape of the second photo. There is a bit of fiddling and dragging to do to get the points to tween properly. After the 3/4 view is finished, I then create another layer then make a 3/4 to full frontal movement or point morph. This gives me a full side to front rotation of the animal to simulate 3D using only two layers under a master switch layer. It takes a bit of effort to set up but the control you can get over the character is amazing and all from a switch layer. Try dragging on the timeline to see the effect.
Cheers
D.K
DK
Post by DK »
Cheers
D.K
DK
Post by DK »
Sorry, here's the link again
http://www.errolgray.com.au/Jawsdemo.zip
D.K
MikeHart
Post by MikeHart »
Thank you very much for the explanation and the file. I will study it later over the day.
Michael
MikeHart
Post by MikeHart »
Mmmh, which tool did you use to zip this up? I can't open it, unexpected end of file.
