i can't understand what happens. before, i worked with the tool and was great. now i format my computer and re installed the tool, but don't works.
the toll is there, but when i click it, nothing happens.
Not really Flip Points but Simulate it...
- Víctor Paredes
...Selgin! (HI!
) remember that you must cofigurate it like a button and not just like another simple tool... Go where the script is installed and add this line... ...where you want inside the _tool_list.txt file and you'll (I think) get it. BTW... SALUDOS!!!
button fa_reverse_points ...- Víctor Paredes
thanks ramón... but this continue not working.
i'm worry, before this tool worked for me.
could i be doing something wrong?
let's see, i make a circle, then i move the point of the right to make it not symmetrical.
i select the reverse point tool... nothing happens. clic the shape... nothing happens. change the...
ok, meanwhile i wrote this message, the tool worked...
forget it.
preferí no borrar lo que escribí, porque es un esfuerzo sobrehumano escribir en inglés, y me da no sé qué borrarlo así como así.
gracias ramón!!
nos vemos por ahí.
forget it.
gracias ramón!!
nos vemos por ahí.
- funksmaname
- Víctor Paredes
This old would work awesome for blend morph. Sadly, I can't make it work well in AS 8. Does anyone what could be wrong?
Thanks
Thanks
No matter how much you insist! This tool have always worked and (it seems) always will do (?)
Well, for me at least... Tested under ASP 8.0.1 without (apparently) any problem. Apart of the button tip, remember that you must have an "asymmetrical" curve/shape and the entire curve (all of its points) must be selected!* BTW... at some point, I should make an icon:
EPIC tool, yeah!
Although, if I remember well, at some point you will have to lead with some kind of unexpected results? But don't quote me on this... Anyway, although terribly advanced, it always have seemed to me a little "preliminary", uhm... it simply scares me! But maybe I'd have to start to play with this kind of things...
* Really... it seems that not all the points of the curve must be necessary selected
EPIC tool, yeah!
- funksmaname
