Not really Flip Points but Simulate it...
i can't understand what happens. before, i worked with the tool and was great. now i format my computer and re installed the tool, but don't works.
the toll is there, but when i click it, nothing happens.
Rai López
Post by Rai López »
...Selgin! (HI! :) ) remember that you must cofigurate it like a button and not just like another simple tool... Go where the script is installed and add this line...
button	fa_reverse_points	...
...where you want inside the _tool_list.txt file and you'll (I think) get it. BTW... SALUDOS!!! :D
thanks ramón... but this continue not working.
i'm worry, before this tool worked for me.
could i be doing something wrong?
let's see, i make a circle, then i move the point of the right to make it not symmetrical.
i select the reverse point tool... nothing happens. clic the shape... nothing happens. change the...
ok, meanwhile i wrote this message, the tool worked...
forget it.
preferí no borrar lo que escribí, porque es un esfuerzo sobrehumano escribir en inglés, y me da no sé qué borrarlo así como así.
gracias ramón!!
nos vemos por ahí.
:cry: i couldnt get this to work... i made the lua and made a button for it, but it just doesnt do anything! what am i doing wrong?
This old would work awesome for blend morph. Sadly, I can't make it work well in AS 8. Does anyone what could be wrong?
Rai López
Post by Rai López »
No matter how much you insist! This tool have always worked and (it seems) always will do (?) :)
Well, for me at least... Tested under ASP 8.0.1 without (apparently) any problem. Apart of the button tip, remember that you must have an "asymmetrical" curve/shape and the entire curve (all of its points) must be selected!* BTW... at some point, I should make an icon: Image
EPIC tool, yeah! :D Although, if I remember well, at some point you will have to lead with some kind of unexpected results? But don't quote me on this... Anyway, although terribly advanced, it always have seemed to me a little "preliminary", uhm... it simply scares me! But maybe I'd have to start to play with this kind of things...
* Really... it seems that not all the points of the curve must be necessary selected :P
I'm not sure how it works out the axis of rotation when you have only part of a shape selected, but i can confirm it's working in v8 here too...
