Weirdness with stereoscopic render
GCharb
Post by GCharb »
Hello all!
Was doing some tests with the stereoscopic render and I am having a weird render with two 3d cubes.
If I render normally, this is what I get.
If I turn on stereoscopic rendering, I get this.
AS Pro 6.2
Anyone has an idea?
G
swrecordings
Post by swrecordings »
it maybe the colors your using a different red/blue setting (.02 instead of .08 for example)
Rhoel
Post by Rhoel »
Agreed, this is an anaglyph problem - the reds and blues are blocking each other: If the blocks were grey, you would see the full cube shapes, with the cyan/red overlays.
Rhoel
GCharb
Post by GCharb »
Hello again!
I turned the cubes to grey and it did solve the problem, did not anticipate that the colors would cause such results. I solved the black bg issue by adding a light grey plane in the back.
Thanks to both of you!
G
joby
Animation
Post by joby »
There is a myth
ASP cant do fbf animation quickly
we can make soon fbf by switch layer mode by using a default dat file
i think
please coment
sorry for my poor english
joby
123qweasdzxc
