embed script drop down
- freecartman™
- funksmaname
- freecartman™
- funksmaname
- freecartman™
ok i used the "combo" on AS6 so now i can export the animations but i have 2 problems
1) i always have a Lua conole's window saying: Meshinstance:wrong order- swap the source and the copy
2) after exporting the "dup" layers don't move, but just the source layers do the action...here it is (sry but it's very very short) an eg. http://www.youtube.com/watch?v=iHfkVp7nWuU
- funksmaname
are the dupes deffinately working in the program?
Try using this one:
viewtopic.php?t=12024&highlight=meshinstance
Try using this one:
- freecartman™
as we say "liscio come l'olio"!!!!funksmaname wrote:are the dupes deffinately working in the program?
Try using this one:
it works fine!! thank you funks!!
This is exactly why being able to save in earlier versions of Anime Studio is essential.funksmaname wrote:this is a recently descovered issue with the multithread renderingit crashes when using morphdials or meshinstance (or both) on AS7 ONLY on machines using multiple cores... we have to cross our fingers it will get fixed soon...!
Re: embed script drop down
Hi, I just discovered this thread and this script is exactly what I was looking for, but I can't make it work.
Do you know if does it work in version 9? If the answer is No, do you know how to fix it?
Thanks.
Thanks.
