newbie notes: this is a pretty complex setup! If you really want to make sense of it more easily, use ramon's 'Lost Layer Tool' to quickly discover every layers masking setting (click a layer and see the top bar for changes)
New improved Head Turn Technique!
- funksmaname
- patricia3d
Thanks for your tricks. Selgin and Neeters Gui.
Now ASP is no more 2D, its 3D.
I had a small problem.
Opened your file
Goto Frame 72
Select head Bone, Open Action Window
Action:AngleRight:Insert Copy
Goto Frame 78
Action:SideRight:Insert Copy
Now Just playback animation and goto Frame 67 to 78, you will see some overlaping problem. Please guide howto sattle it and Please guide howto create an action for AngleLeft and SideLeft. It will be so great.
I know I can change the layer order to hide Right Ear behind the head, but which one to put ( Original or Dup) in the Actions?
As you have suggested for tweeking the points in your PDF manual, which layer to use Orignal, or DUP?
Opened your file
Goto Frame 72
Goto Frame 78
- neeters_guy
That is fixed by moving the "ear_R" layer under the "face" layer in frame 67.kkrawal wrote:Now Just playback animation and goto Frame 67 to 78, you will see some overlaping problem. Please guide howto sattle it and
Heh, well I was going to leave that up to youPlease guide howto create an action for AngleLeft and SideLeft. It will be so great.
The original because...I know I can change the layer order to hide Right Ear behind the head, but which one to put ( Original or Dup) in the Actions?
...The dup layer, as I understand it, is the mask for the original layer, so I typically never touch the dup layer.As you have suggested for tweeking the points in your PDF manual, which layer to use Orignal, or DUP?
I found a mistake in the notes, the part about which frames to fix: Not frame 112 to 118, but frames 106 to 112.
Anyway, thanks for the feedback.
- neeters_guy
You're welcome. Yeah, I still don't get how the masking works...I just set it and forget it.funksmaname wrote:nice one neeters - beautiful! Thanks for sharing
Now how do I apply Rudiger's Morph Dials to this?
Edited to include link to correct topic. Please continue here:Bone morph dials script
- funksmaname
DarthFurby
Neeters - WOW. You totally, totally hit that one OUT of the PARK! I usually export my stuff in vector format to a compositor so I avoid masks whenever possible, but now I might have to reconsider. I will be studying that file. Awesome awesome awesome.neeters_guy wrote:For those of you who are curious about how I adapted Selgin's set up, here's an AS file (ver. 6.2) that you can pick apart:
NG_SelginHeadTurn.zip
I also included my notes (in pdf and open office format) if you want all the messy details. Hope some of you find this useful.
thehj - wish I could help, but I've never used the meshinstance script before, tho I understand what it does.
- funksmaname
I've been playing with this script over the past few days and all I get is an error that i move to the side, I have not seen a crash yet.funksmaname wrote:It's crashing here toothis must be due to the same multi-processor bug that is affecting morphdials... damn it (do you use a multiproc amchine?). Rudiger has been in touch with Mike about it, and It should hopefully be fixed up soon...
Windows XP, single core.
Stephen
DarthFurby
Sorry I forgot to say I'm using AS7 Pro.sbtamu wrote:I've been playing with this script over the past few days and all I get is an error that i move to the side, I have not seen a crash yet.funksmaname wrote:It's crashing here toothis must be due to the same multi-processor bug that is affecting morphdials... damn it (do you use a multiproc amchine?). Rudiger has been in touch with Mike about it, and It should hopefully be fixed up soon...
Stephen
- funksmaname
- neeters_guy
Here's a more streamlined version: NG_SelginHeadTurn2.zip
The mouth is simpler to avoid the tangle of points in the other file. Also, I added actions for full and partial, left and right views (access in the bone layer), so you can do a 180 degree turn like this:
As with the previous file, you will need to adjust the layer order of the ears and tidy up points as needed.
DF -- Thanks for the comments
. Selgin and Fazek are heroes for making this possible. I feel they're the scientists and I'm an engineer applying the concepts.
- funksmaname
