Ah I know what you mean; yeah, some more steps would be possible. I will make it better next time, thanks for the tip!
The music is 100% done in the computer; no recordings this time (but mainly I like to record live instruments, if I have the option and the time to do this(
example)!). The brasses and woods are done with WIVI (wallander instruments) and the strings are from Symphobia. For my taste WIVI+Symphobia is the best mix of virtual instruments I have ever had; I love to work with this tools / plugins. Moreover a very short working process-description for the music, if you like:
- I cut the whole film into 7 pieces, where I wanted to be music in one piece (7 cues)
- After this I made a cue-list for every "cue"; I'm not sure, if this word is known: a cue-list has cue-points; cue-points are some time-marks on which the music has to be somehow
- I loaded the 7 files in 7 seperate music-projects and set the cue-points into my music software (FL Studio)
- Then I just composed the music fitting to the scene
- I rendered the music into waves, put them into the end-mix, etc... you know
If you or someone else has more questions about the musicproduction, I will certainly answer it. after all you guys also help me here on the graphical site, so maybe I can help you in some music-questions.
