Line Hiding
Datawraith
Line Hiding
Post by Datawraith »
Is there a way to have certain lines on a vector layer visible in one frame, and then hidden in another frame?
A device that makes bad weather. . . interesting :/
only by animating their width as far as i know - at 0 they will not show, so you can animated the width at two points that make a line to make that line invisible and then grow it over a single frame or more to its normal size to make it show again.
Datawraith
that did it! thanks =D
neeters_guy
Post by neeters_guy »
Once again Selgin has discussed this idea before here:
hidding/showing lines for facial expressions
Also contains a nifty example by funksmaname.
we get about ;)
