Intermediate shape stacking technique screencast...
Hi all,
I wanted to try this screencasting thing out, so thought i'd go over a couple of techniques i like to use. I described this before in text, long time ago, but thought it might be easier to follow as a video...
Hope you find it useful, post any questions below.
please note: no masking was used in the creation of this video :P
--- edit:
my tutorial links are dead :(
I'll re-do them and upload to youtube sometime...
sbtamu
Post by sbtamu »
Hmmm I might use your way, I been using a mask. Those 2 lines you made from the mouth's corner to the face's edge to create the shapes seems to be a better way than what I been doing. Thanks for sharing.
Stephen
Sorry for bad animation
neeters_guy
Post by neeters_guy »
Very well explained, one of the better tuts on face construction techniques. Thanks for sharing.
thanks for watching :)
I think the stacking order thing is one of the fundamentals of working with anime studio, and no other program i've ever seen has this ability - it's so powerful when you get your head around it!
Just one comment to that classic technique: To speed up animation (without using bones) you can make use of point groups. When selecting lower llip + lower teeth + tongue you can make use of groups for quick point selection. It will speed up animation process.
fracturedray
Post by fracturedray »
Very good tip! I would have been going crazy doing this all with layers. :)
Hi animation world.
Ryder
Re: Intermediate shape stacking technique screencast...
Post by Ryder »
funksmaname wrote:Hi all,
http://www.screentoaster.com/watch/stUE ... xYWV5YVVZd
suplimental: a more localised use, not using outer head shape
http://www.screentoaster.com/watch/stUE ... xYX1lYX1Rc
Sadly, neither of these links are working for me... hrmmm
DarthFurby
Post by DarthFurby »
Loved it! The second video seems to stop about halfway thru tho. Hope you make more. I'm a multi-layer guy myself, but have to admit the single layer method is far easier, and better for certain types of projects.
Thanks DF :)
Dunno why the video appears to stop... stupid system doesn't let you fast fowrad either! Ryder - i can get to the links, try again?
Next time i might try to upload to youtube instead!
Ryder
Post by Ryder »
funksmaname wrote:Thanks DF :)
Hey, worked this time... not sure why :) Thanks!
Styla
Post by Styla »
Perfect tip!
Face creation was really a tough part of any project always, really interesting!
Thanks for sharing!
Tagirijus
Post by Tagirijus »
Just recognized your tutorial (because of your signature). Great thing and looks very easy. I am going to test this technique and I am also going to watch your other videos. Thanks for sharing this! :)
neeters_guy
I thought I would try Funksmaname's shape stacking technique on a simple head turn. It's a great setup if you don't need a full side view and it's all on one layer too.
You can download the file here.
I should mention two "cheats" that I used on this rig:
1) The nose shape is a simple flip using a step key. This usually looks jumpy, but I tried to use it when the head is turning quickly to make it less noticeable.
2) I wanted to put the ears in one layer rather than on separate layers, but you cannot animate shape order in the same layer. However I found a clever workaround in this thread:
Shape ordering in single layer.....(?)
This graphic should explain how it works:
Anyway, hope you all find this variant useful.
