Hi all,
I was just wondering what resolution you guys use. After adding some scripts to the tool bar I found that my time-line was buried so low I could not see but one line. I had my resolution at 1024x768 and changed it to 1152x864 keeping aspect ratio and now I have plenty of time-line to see but now I can hardly read the text because they are so small. Is there any way to have more time line show with the lower resolution with out detaching the time-line?
P.S.
My screen is a 32 inch flat screen HD TV. set to 16:9.
Thanks,
Stephen
screen resolutions
- fracturedray
Thanks for the replies.
Ray, how can you read whats on the web with such high resolution? I tried 1920 x 1080 and I had to get right up to the TV to read any text that was on the web.
slowtiger, I can not seem to find a way to resize the tool or style palettes I can only detach and move them. But after going to a higher resolution I found that I have plenty of time line now with a 1152 x 864 instead of the 1024x768 I was using.
Genete, 1152 x 864 is actually a good solution for me. After looking at it for awhile I have adjusted to the slightly smaller text and images. Also, my chair was about 4 feet from the TV, I moved the chair up a tad.
Thanks
Stephen
Thanks
Stephen
- fracturedray
