How do I edit TEXT once inserted?
I'm finding it hard to see if it is possible to edit text once it has been inserted into a layer.
I'm using Anime Studio Debut 6.
Is it at all possible? for it would make it simpler for me to change current text, which then would behave the same way as original animated text I've created?
Would love to hear any views or solutions to the problem or an other way to get around it?
Yes, I am going to have to look in to using a site.
Does anyone have a favorite, with free being a leading factor.
Leave the "Create one shape" box unchecked and you can treat the letters as vector shapes. They can be moved, fill and line changed, anything you can do with vector shapes. The only thing I would hesitate on would be changing the font. Too much work doing that. I would put text on it's own layer so I could redo the layer instead of trying to rearrange everything.
I have been having fun putting text into a physics group, sliding them off a ramp into a fan motor or just dumping them on the ground and watching them bounce or dropping a ball on them and watching them scatter.
I just had an idea. A pachinko machine with letters.
This may not be helpful to you but I created a "font" script or tool for AS that creates just stroke shapes. I use it for labeling bones and writing instructions. Because it only uses strokes and the font is VERY simple it keeps the files from getting hard to work with using regular font shapes.
The font isn't "pretty" though mainly "functional".
viewtopic.php?t=16616
Thanks for your help and responses.
Thanks G, Cyberife, Imago and Vern,
for all your help on this.
All the comments have been really helpful.
I've attacked my immediate issue with importing the text
as image then replacing the source file in the layer, so the behavior
and key frames etc stays
the same the same. Not ideal, but works for the current situation.
I will explore other alternatives before my next project.
( just around the corner).
Cheers,
GV
Cheers,
GV
- DigitalDesignDude
Re: How do I edit TEXT once inserted?
I'm glad there are editable text layers in Moho now as the following video shows:
https://youtu.be/QofwaKHOhRA?si=6H4_M-sxoePKDWR5
I know this is an old thread to re-open, but it shows up as the first Google search result for "edit text in Moho", and so I hope my response will help others like myself who were wondering whether it's possible or not.
Good luck with your projects all!
