Setting line thickness *after* drawing?
taapo
Post by taapo »
I must go mad, since this fairly easy method doesn't work in AS7 (and maybe others)?
I draw a closed shape. I can change the line thickness without a problem.
I go to another layer. Go back to the original layer. Select all the points of the shape I made. I try to adjust the line thickness in the style menu ... it doesn't work. What am I doing wrong?
PS. I approach this from an Illustrator background, so maybe I'm overlooking something?
hothead
Post by hothead »
1. change the line thickness value in the style width area 4 to 20 any value you want
2. select the paint bucket tool and refill the shape
the line thickness should change
You must select the shape, not the points.
If you select the shape of the line you want to change using style window, it will work fine.
If you select the points, you can use the line width tool.
PD: I don't recommend to re fill the shapes, it could cause some disorders on the layers. It's not sure, but it could.
taapo
Post by taapo »
Awesome. Such a simple thing =( Sorry guys, and thanks for the advice!
hothead
Post by hothead »
your welcome dude
